P/N Request-Front Strut Mounting Hardware
And do you remember if the bolt itself is flat-sided or otherwise non-turntable?
And now that I have a good pic of it, it appears that at least one side of the bolt is flattened? Hmm. I’m going to try to get a wrench on it.....
This is is what comes up as the OE bolt. Looks like mine.
This is what comes up as the “bolt repair kit”. It looks like yours.
I don’t think the bolt turns either way. Ugh. Ordered both to be safe. Back to work.
Interesting notes from WIS. 1) it says to unfasten the cooler so you can move it around for your bolt, and 2) right underneath it says to NOT turn the bolt.
Guess I’m going to try and turn that nut....
Can’t get a wrench or socket on the bolt side, zero space. If I try to heat and snap the bolt head, there’s no room to take the bolt out through the other side. If I take the sawzall to the bushing and can’t get through the bolt I’ll really be screwed. I’m really at a loss now. Might just put everything back together and let it be someone else’s problem, hopefully with better tools.
Really annoyed, this should have been easy.
The problem is that I can’t get a wrench or socket on that nut. There’s just no clearance and the swaybar is in the way too.
I’ll get back under and see and see if I can figure it out. Thanks for the tips!
Last question for this hijack Mort (sorry). Can I turn that bolt now to unscrew it, or is it shaped in a way to only turn the bushing? Thanks
There are 3 tabs on the lock washer make sure they are all released.
You will be able to get on it without too much trouble from out side the swaybar and the wrench is 22mm. I just reached under the car with it sitting on the tires and was able to get an open end wrench on it.
And thanks. Glad to know it wasn’t just me that thought this two bolt job was actually more difficult than you’d think from observing the part.
Been hammering at the bolt for 2hrs. It turns freely and spins the bushing with it, but won’t come out. Seems that the bolt is seized to the bushing sleeve. I’m pretty close to taking the sawzall to it. What a mess.
If you're replacing the bushing, use a torch then a spray bottle with cold water.
