LSD oil change interval
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
Hi,
I recall reading that the rear diff oil should be changed once at 3000 km and then it’s good for life. However, the service manual says once at 3000 and then every 4 years/60000.
Which is correct?
thanks
Which is correct?
thanks
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Rear diff oil isn’t good for life. Whenever in doubt, follow the schedule in the service manual.
If you don't have a limited slip, I would change it but since there is no material contaminating the fluid like in a limited slip, probaby 60-75k is when I would change it.
Surge (04-05-2019)
What is a reasonable cost to get this done at the dealer?
I do my own oil and brake fluid flushes, but I don't have a lift...
