C63 AMG (W204) 2008 - 2015
Best way to check motor mounts
Old Apr 22, 2019 | 09:14 AM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Hi guys,
Watching that video of the guy revving the motor and seeing it rotate nearly 45 degrees in the engine compartment got me thinking... I'll come back in include the video if I can find it.
Question is: how much 'flex' should a motor on healthy mounts have? In other words, how much movement suggests a visual inspection of the mounts makes sense? Mine moves about a quarter inch when I rev it in neutral.
EDIT: Answered my own question and nominating myself for Stoopid Post of the Day. This helped.
Thanks,
-Bones
Old Apr 22, 2019 | 01:42 PM
Amr_c63's Avatar
14 polar white E550
Lift the car , remove front under panel and try to slide your fingers through the sway bar and also the engine , if your fingers slide through without a problem then they are fine . If they don’t then they are bad . Also another indication for bad motor mounts are a vibration at idle while stopped .
Old Apr 22, 2019 | 03:29 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
There's a few pics of failed mounts here --> https://mbworld.org/forums/c63-amg-w...on-mounts.html
You can visually see if any oil has leaked out.
