C63 misfiring
C63 misfiring
I have just changed all my headbolts over and the car is getting a few misfires
Codes are
p0135
P2243
P0130
P0436
P0583
P2193
The first 3 are related to bank 1 sensor 1 so I'm assuming the pre cat o2 sensor is not working.
I have misfires (on torque ) on the following cylinders on my last drive
cyl 1 0
cyl 2 1
Cyl 3 0
Cyl 4 1
Cyl 5 6
Cyl 6 22
Cyl 7 298
Cyl 8 13
So it looks like cyl 5 to 8 are misfiring. Does this correlate to the side of bank 1?
Codes are
p0135
P2243
P0130
P0436
P0583
P2193
cyl 1 0
cyl 2 1
Cyl 3 0
Cyl 4 1
Cyl 5 6
Cyl 6 22
Cyl 7 298
Cyl 8 13
You sure you didn’t miss any torque of bolts or missed plugs? Otherwise try the primary o2 which is common for miss fires however seems since you had a lot of parts off might have missed something. Timing correct?
Well Iv put in 4 new O2 sensors and it's still misfiring.
Back to the shop it goes I guess.
Not sure if the timing is correct or not as the shop put the head bolts in
