How to open throttle body electronically
Is there any way to electronically open the throttle body so I can get a borescope inside without taking the intake manifold off?
I'd like to electronically open the manifold while the engine is not running if possible.
Carbon build up can be also from clogged fuel injectors and an off air fuel ratio.
i recommend taking intake manifold off and cleaning and inspect the ports. Also smoke test your intake for leaks.
