2010 C63 AMG (open heart surgery)
After a full week of trial and error , the car is finally back up and running.
This is like Chicken Pox for the AMG...it's bound to happen eventually. You just gotta be ready to treat it.
I'm am by NO MEANS a mechanic, but I believe me and the 63 have become ONE with this process.
So if you have any concerns about your whip with sounds, feel free to ask...I'll do my best to steer you in the right direction.
I didn't find setting the timing hard using the tool, as long as you set the timing mark before you dismantle the camshafts.
Mine has 100k/klm so did a major service,
I replaced the spark plugs, injectors, air filters, pulleys and belt from FCP Euro.
Also used Liqui Moly 5w/40 with Ceratec and the engine just purrs now.
On the tool note I bought one off Amazon (anodized red plate with markings) and a used one off eBay.
But the used one (silver plate with no marknings) must have been a cheap chinese knock off because the plate holes didn't line a with the front cover bolt holes and the front camshaft locking tool didn't line up with the valve cover bolt holes.
We are only talking the tiniest margins but the short of it is they do not line up.
What I did salvage out of the kit was the adjuster timing gear locking tool which made it easy to remove both camshafts at same time.
