C63 AMG (W204) 2008 - 2015
List of C63 problems?
Old Oct 17, 2019 | 11:09 PM
JChi23's Avatar
2001 Lexus GS430
Noob here, trying to compile a list on what to look out for. I understand headbolts are preface lift with some early 11s.
From what I've read the below are problems for any year W204 C63
-Camshaft wear
-Lifter wear
-Cam shaft adjusters
Have there been any answers to these problems? People seem to go 5W40 for the Cams/Lifter wear, outside of that I don't know.
Anything else that should be looked into? Thanks
Popular Reply
Oct 17, 2019, 11:36 PM
BLKROKT's Avatar
BLKROKT
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
In before BLKROKT
Old Oct 17, 2019 | 11:36 PM
BLKROKT's Avatar
In before BLKROKT
Old Oct 19, 2019 | 01:18 AM
JChi23's Avatar
2001 Lexus GS430
Originally Posted by BLKROKT
In before BLKROKT
I was trying to see if the above has been fixed. The fuel injectors are also a problem, but replacing them looks pretty easy.
As for the aforementioned, I've found no solutions and it seems the only thing you can do is replace the Cam Adjuster, Shaft, and lifters, etc. Some users have had ticking even on newer models at low mileage.
Old Oct 19, 2019 | 02:56 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
correct no permanent fix. Some have had luck with the pin flip on the adjuster to stop the clatter.
Old Oct 20, 2019 | 11:09 PM
roadtalontsi's Avatar
10 C six trizzle
cheap owners, only worried about going fast. they are turning into the 55k crowd.
cheap owners cant afford to maintain a $70k car
anything since some of these cars are going on 11yrs. you name it, it can happen.
Old Oct 21, 2019 | 06:25 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Very quick to get knocked out of alignment.
The transmission can get flakey
Steering wheel does not come back on center after making a turn
The blue oil smoke "cloud of death" after restarts
Old Oct 22, 2019 | 10:48 PM
JChi23's Avatar
2001 Lexus GS430
I wouldn't necessarily call someone cheap for not pulling an engine to do 'maintenance'
In the meantime I'm still deciding if I should plunge into the AMG world. I don't care about paying $1200 for tires, $250/month for gas, and a few $800 repairs. I'll see if someone comes up with the above fixes, but I'm doubtful.
Thanks for the feedback
Old Oct 23, 2019 | 11:19 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
During the 5 years that I owned a 2010 C63, the only thing that I ever replaced was the PCV valve, brake pads and rear tires.
Old Oct 23, 2019 | 11:56 AM
SuperFastYo's Avatar
C63 AMG - LSD
In before BLKROKT
LMAO I miss this forum.
well apparently the entire control module for EBD, ABS and ESC
Old Oct 23, 2019 | 12:34 PM
BLKROKT's Avatar
OMG please keep us updated, the suspense is killing me already
Old Oct 23, 2019 | 12:39 PM
JChi23's Avatar
2001 Lexus GS430
Sure thing pumpkin
Old Oct 23, 2019 | 12:53 PM
C63 AMG - LSD
Old Oct 23, 2019 | 01:37 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Any car can have any type of issue come up, but honestly, the m156 engine holds up really well.
Tires - every car needs them, really about research and finding deals.
Gas - really depends on how you drive. Manual mode I get 12-14mpg. Comfort I get 20-22mpg.
Repair costs - up to you (dealer vs diy).
Just be smart and do your research.
Old Oct 23, 2019 | 04:48 PM
Homer Oz's Avatar
C63 AMG Coupe
G'Day Fella's,
JChi23, the only issue I'm aware of, is a slight oil weep/leak, from the rear of the Left engine valve cover (C63-V8).
I see on this forum, that others also have experienced a simiar oil leak.
Hope that helps.
D'oh!
Homer
