C63 Gear Shift and Power Loss at WOT
Hi folks,
Here is a detailed explanation and observation of my problem -
1. Car seems to start and idle fine. No rough idle
2. in S+, car seems to pull fine with slight hesitation during the gear shifts from 1-2-3, but this hesitation is negligible
3. from 3-4 at wide open throttle, the car just bogs down before shifting to 4th. It’s almost like it ran out fuel or air
4. after a very hard run when car shifts from 4-5, I have the same problem
5. After hitting the car hard, when I take a turn (corner) and the car has to shift from 4-3-2-1, it’s like the car has lost complete power and I have no acceleration left
6. if I let it just stand for a few seconds, she sputters back the power and moves ahead with the same problems as listed above
7. the above happens almost like clock work precision ruling out any issues of Spontaneous problems
What I have done -
1. Swapped the fuel pumps (both side) with another C63 to rule that out and the Problem still persists
2. changed air filter to ensure that it wasn’t clogged
3. I thought it’s the tune, so I removed and put the stock ECU , same issue
4. I ran through the battery reset process for ECU and TCU adaptation
5. I Also did the TB reset procedure
Pending to do -
1. I have a 82 mm TB. I think that could be the culprit
2. I recently changed the plugs, maybe the gaping is not proper
3. tank clean up to check for impurities and debris in the tank
any one faced this issue before ?
any help here is highly appreciated
What I have done -
Pending to do -
c63ams (03-07-2024)
Unfortunately, no check engine light. The throttle pedal has been replaced 1 month back. That’s to do with the integrated TPS which was putting car in limp mode every time I would use the kick down switch. That problem is solved
That’s the problem, I changed the plugs 10
days back!! So I have to rule out
1. plugs
2. injectors
3. fuel pump
4. transmission service
i am suspecting the throttle body. Will swap back stock and see what happens here
1. plugs
2. injectors
3. fuel pump
Hey, I have the same problem with my W205 c63s coupe. In 3th gear when I go WOT the car accelerates hard to almost red line/shift point the car cuts power does not want to go to 4th gear (feel like hesitates / sputters...feels like lack of fuel or power.
Did you find the problem? please let me know thanks!!
Originally Posted by c63ams;[url=tel:8935479
8935479[/url]]Hey, I have the same problem with my W205 c63s coupe. In 3th gear when I go WOT the car accelerates hard to almost red line/shift point the car cuts power does not want to go to 4th gear (feel like hesitates / sputters...feels like lack of fuel or power.
Originally Posted by marrss;[url=tel:8949433
8949433[/url]]Hey did you ever figure anything out? Going through the exact same thing right now, I can go all the way through 3rd at half throttle with no issues but if I go WOT and go all the way through 3rd it goes to soft limp mode as soon as it shifts to 4th and I get no boost at all
