C63 AMG (W204) 2008 - 2015
Rough idle, fuel pressure error on full tank m156
Old Dec 15, 2019 | 04:27 PM
Viktori's Avatar
C63 AMG W204
Hi there,
posting here cuz community of c63 much bigger than ml63, engine is same.
I have rought idle on D when I stopped on red traffic light, engine and transmission trannys was changed and thats not helped. No errors on that thing.
Found errors only on full tank
3699 Fuel pressure control: The upper limit value is reached P0191 // come first time right after refuel till full tank
3699 Rail pressure sensor has malfunction // second time
anybody knows what a hell is going on?
No check engine, checked vacuum leak, didn't found anything.
Checked by star diagnosis fuel pumps, both give normal voltage.
I saw lot of threads about P0191 and seems there is no solutions, or maybe I didn't found any?
Old Jun 28, 2022 | 08:02 PM
CaveMan0183's Avatar
2009 ML63 AMG
Did you find a solution? I’m having a similar problem with my 2009 ml63.
thanks!
Old Jun 29, 2022 | 06:01 AM
Viktori's Avatar
C63 AMG W204
Exclamation
thanks!
Hi,
errors due fuel pump which was replaced
Rough idle was fixed by replacing chain tensioner.
Old Oct 8, 2022 | 01:45 AM
Intor_thexx's Avatar
2014 c63
Originally Posted by Viktori
Hi,
I'm having issues with my 2014 C63 it has a code stored 3699 I replaced the crank case event tube fuel injectors and fuel filter as well as the fuel rail pressure sensor Any idea of what it might be?
Old Oct 8, 2022 | 04:18 AM
JonsAMG's Avatar
2010 C63
I'm having the same code. I also replaced my fuel injectors, fuel pump and spark plugs. I get random very rough idle that often leads to the car stalling multiple times before running fine again.
Old Oct 8, 2022 | 11:00 AM
Viktori's Avatar
C63 AMG W204
you both should ask for smoke generator on car repair stations to check if engine have vacuum leaks
