RTV on cam adjuster cover bolts question
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
For those that have had the cam adjuster covers off, WIS says to put RTV on the 5 bolts that hold the cover on, not sure why as all the bolts are outside the seal so really should be no oil there. Just wondering if others have done this and if they just put a little around the bolt head as WIS is not very specific.
Rob
Screw bolts (6) into cap (7, 8) n *BA05.20-P-1002-02J
Loctite 5970 sealant
Rob
Thanks, seems there is none there from the factory and I had the cam adjusters done 3 months ago, so they were off and none indication of sealant on the bolts after that either, so will go with none then as you have had no issues.
