C63 AMG (W204) 2008 - 2015
Tune and charging battery Question
Old Apr 8, 2020 | 02:55 PM
csandbothe's Avatar
2003 Audi S8
After I upload the tune, I understand that I need to unplug the battery overnight. Just the negative cable ok? At that point, I have to charge from the battery itself, correct? Where do I clamp the negative cable in the trunk? I can't locate an appropriate spot. Thanks for the help.
Old Apr 8, 2020 | 03:03 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Just disconnect the battery overnight. Then reconnect it, start up and go. That’s it.
Old Apr 8, 2020 | 03:19 PM
csandbothe's Avatar
2003 Audi S8
No need to charge the battery while disconnected?
Old Apr 8, 2020 | 03:44 PM
BLKROKT's Avatar
Only if it’s low. Stick it on a charger if it makes you feel better. If it has enough charge to start the car it’s fine.
Old Apr 8, 2020 | 04:05 PM
skratch77's Avatar
2005 E55
unplugging the batter will save power. You don't need to unplug it if u have star setup. Just go in and do a reset and all pending can codes are gone.
Old Apr 8, 2020 | 05:03 PM
csandbothe's Avatar
2003 Audi S8
Thanks guys.
