C63 AMG (W204) 2008 - 2015
CATLESS TUNED FULL E85 C63
Old Apr 24, 2020 | 08:46 PM
scrappykoko63's Avatar
c63
Just dynod my C63 with nothing other than no Primary & Sec cats along with K&N drop ins and a flash for FULL E85 from eurocharged. Anyone with similar mods make more? STOCK HEADER
Old Apr 24, 2020 | 08:54 PM
Black_Mercedes's Avatar
C63 P31, C320
Been on full E85 for awhile. Did you get new injectors?
Old Apr 24, 2020 | 08:59 PM
c63
just got the file been adapting it by going on dyno. on stock injectors.
Old Apr 24, 2020 | 09:05 PM
C63 P31, C320
Check that duty cycle.. With just Second Cat delete and res delete on stock injectors is 95% injector duty at 82% E85. Im installing longer tube headers next week with 630cc injectors to put me back in the safe zone.
Old Apr 24, 2020 | 09:10 PM
Crya's Avatar
2009 C63 P30
Don’t want to spread FUD but I seem to recall chatter about no primaries needing the larger injectors. Did Jerry do the tune? Did you see anything on afr that raised any concerns? There is inconsistent info coming out of Eurocharged because when I inquired about a dedicated E85 tune for a non-LTH car on stock injectors, I was told the dedicated tune could run up to E50, which is not what’s at my E85 pump.
Old Apr 25, 2020 | 10:14 AM
C63 P31, C320
Which you would be correct. 95% duty cycle for me with main cats still in place at 82% E85. With long tube headers i would be way over 100% with no cats i would assume would be the same thing.
Old Apr 25, 2020 | 12:06 PM
LSAMG's Avatar
2013 C63 AMG Sedan
is S/C next like Gil?
Old Apr 25, 2020 | 12:21 PM
c63
ha nah maybe a 205
Old Apr 25, 2020 | 09:20 PM
MSalhieh's Avatar
W204 C63 Coupe - Full Catless, E85, Nitrous
don’t need injectors for full catless. I run full catless, straight E85 for the past 5 months. No issues. Duty cycle around 95%. LTH need injectors for sure. I am dyno tuned (Jerry) and put down 491whp on a mainline hub dyno.
Old Apr 26, 2020 | 07:47 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
how are you tracking duty cycle?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Apr 26, 2020 | 08:07 PM
C63 P31, C320
Eflexfuel App for me. With 82% E85 with cats still installed is 95% injector on 5 different pulls. If you are fully catless and no res you are way above the threshold.
The change in E85 from station to station can be way different. One of my station has 74% and the other "shell" is around 81-83%. If your in the safe zone on the lower end one you'll pass that mark when u get some good E85
Old Apr 27, 2020 | 12:41 PM
swedepat's Avatar
2011 C63 AMG, 589hp
Hub dynos shows a lot less losses than rolling road dynos.
Due to no tires....
Old Apr 27, 2020 | 03:12 PM
MSalhieh's Avatar
Due to no tires....
Agreed but I’d rather have a more accurate reading due to no loss.
Old Apr 27, 2020 | 03:14 PM
MSalhieh's Avatar
I logged via HPTuners to check injectors, etc. on pulls.
AFD PROFLEX app for me. E85 stations always read 80-83% here
Old Apr 28, 2020 | 12:16 AM
Mag1c Carp3t's Avatar
2009 C63 AMG
This was with E70 and a remote 91oct tune from Jerry. Never got tuned for ethanol but the car would have been over 500.
