C63 AMG (W204) 2008 - 2015
Catch Can Help
Old May 30, 2020 | 03:58 PM
NoahWeb's Avatar
R63 AMG
Catch Can Help
Greetings all! Finished installing a VRP Catch Can on my M156 powered R63 today. After a short shake down drive, 25 miles or so, returned home to find some oil spray on the radiator, underside of hood, and cam shaft covers. Appears to have sprayed from the dip stick. The lines are about 48-52” each. I checked the catch can after the drive and it was bone dry.
Waiting for the engine to cool now before taking a look, but wanted to see if anyone had some thoughts.
Thanks!!
Old May 30, 2020 | 10:59 PM
Carbonjake's Avatar
2010 C63
Plumbed backwards perhaps?
Old May 30, 2020 | 11:21 PM
Mort's Avatar
Definitely blocked up at some point in the plumbing.
Old May 31, 2020 | 08:51 AM
NoahWeb's Avatar
R63 AMG
Got back into the engine bay and the lines were in the correct out/in. I suspect, given the tightness within the R63 engine bay, that the feed line for the inlet was turned to sharply and there was insufficient flow. Removed the lines and can, reconnected the OEM, and will have a re-think on placement within the engine bay. Wish there was more room!
Old Jun 13, 2020 | 01:35 PM
NoahWeb's Avatar
R63 AMG
Re-installed today with the can being installed behind the intake split and lines trimmed to 10-12”. No kinks or abnormal bends; free flowing hose 1/2” hose. All fittings tight and secure.
Same problem. Oil being blown out of the dip stick. At this point I suspect the lines are to small to flow sufficient air out of the crank case resulting in the pressure having to go somewhere....like the dipstick.
Any thoughts from the more experienced M156 gurus??
“In” towards the front, “out” towards the rear.
Old Jun 13, 2020 | 02:16 PM
fflmlf's Avatar
2013 C63
You've still got a pinched line or a blockage somewhere. Does air flow thru the catch can if you blow on the inlet hose?
You're lucky it's blowing out the dip stick and not thru a front or rear main seal, don't drive it until you get it figured out.
Old Jun 13, 2020 | 02:58 PM
NoahWeb's Avatar
R63 AMG
Yep; you can blow in the “in” side and it comes out freely on the “out” side (vice versa as well). Already reverted back to the OEM setup to prevent any damage while troubleshooting this.
Old Jun 13, 2020 | 04:32 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I just emptied mine that was installed a couple months ago for the first time at the reccomended 3000 miles. How much oil should I expect to see? There was like maybe around a table spoon. I didn't really measure it.
Old Jun 13, 2020 | 05:50 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
When I opened the can’s drain spout I got nothing but when I took the catch can out of the car and tipped it I got maybe a quarter cup, in approximately a couple months worth of driving.
to the OP did you swap out the old PCV too? Maybe a bad valve?
Old Jun 13, 2020 | 08:08 PM
NoahWeb's Avatar
R63 AMG
the valve is about 20k miles old; reasonably new. I’ve been wondering the same since posting this. No issues with the OEM setup though.
Old Jun 15, 2020 | 05:49 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
I am not sure if this is related or not but here goes, do you have the updated/ revised oil dipstick?
I believe the ML63 & R63 share most parts. My ML used to push the dipstick out and blow oil all over under WOT. The M156 engine in my car has a large breather tube (NOT A PCV!). The updated dipstick sits in place and doesn't move at all.
Good luck.
Old Jun 15, 2020 | 08:45 PM
NoahWeb's Avatar
R63 AMG
Good luck.
Great point! I’ve looked for A 156 010 05 72 and have yet to find one in stock. I believe that’s the updated Part Number. Anyone have a solution to source a dipstick!?
Old Jun 15, 2020 | 10:27 PM
bhamg's Avatar
C63 AMG
I called two dealers a few years ago and they both had the updated dipstick in stock. IIRC I paid about $12.
Old Jun 17, 2020 | 08:39 PM
NoahWeb's Avatar
R63 AMG
called my local dealer today. $57 with shipping; shipping being more than the stick!! Be here on Friday!
