C63 AMG (W204) 2008 - 2015
HRE Wheel Dimensions
Old Jun 4, 2020 | 07:31 PM
JumboNate's Avatar
2015 (Final-Year) Fully-Loaded W204 M156 Custom Mercedes-Benz Designo C63 AMG Edition 507 Coupe
Question HRE Wheel Dimensions
I am looking at a set of new HRE wheels.
Forged Monoblok RC103.
'15 W204 C63 AMG Edition 507 coupe.
19-inch diameter.
Michelin PS4S
Front: 245/35ZR19 (93Y)
Rear: 275/30ZR19 (96Y)
There are two options that I have to select from. I don't understand them...
(19" x 8"), 0 to +80 Offsets, 5x100-130 Bolt Pattern, 50-120mm Hub]
or
(19" x 8.5"), 0 to +80 Offsets, 5x100-130 Bolt Pattern, 50-120mm Hub]
8 or 8.5? What's the difference?
Old Jun 4, 2020 | 07:37 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
19-inch diameter.
Michelin PS4S
or
I run 8.5s in the front and 9.5s in the rear.
Old Jun 4, 2020 | 09:53 PM
toosteeley's Avatar
Present: 2019 C43 Estate
Buy mine instead
https://mbworld.org/forums/c63-amg-w...hre-590rs.html
In all seriousness, the difference is rim width. You’ll want 8.5 for the front.
Old Jun 5, 2020 | 09:00 AM
thewb's Avatar
SPONSOR
www.wheelsboutique.com
19-inch diameter.
Michelin PS4S
or
Hey Nate. We're the largest dealer in the world for HRE Performance Wheels so it'll be our pleasure to help you better understand what you're purchasing & help you with your order.
The 19" is the diameter of the wheel. The 8" or 8.5" is how wide the wheel is. The 0 to +80 offsets is a range that you can choose the offsets in. The offset dictates where center mounting point of the wheel is located within the width of the barrel. If the offset is too high then the wheels will be sitting tucked inside the wheel well and could potentially hit struts or the fender liner. If the offset is too low then the wheel may poke out passed the bodywork of the car. We have built HRE's for the W204 C63 hundreds of times over the years so when you purchase with us you won't have to worry about choosing the offset on your own. We know what works perfectly & guarantee the fitment. Same goes for the bolt pattern that you need to choose as well as the hub bore.
Reach out to me directly and I can help you every step of the way - David@WheelsBoutique.com || 786 249 0127 ext. 2109
