Problem with the oiltemperature display
Hey guys,
i bought a c63 from 2010 and noticed
a problem i think its a software problem but here are guys who will know more i think.
i have the amg mode where you can see the temperature of engine and transmission. Both are never constant and always changing 1 celsius 3 celsius sometimes 10 celsius up and down. It cant be the true temperature it goes always up and down with no sense. I took a video where you can see.
what could it be? I think the sensor works cuz i dont hear anything wrong working on radiator fan. And the transmission is the same thing so i think its something with the software?
here a short video
here a short video
Yes the oil temperature doesn’t seem accurate I’m guessing a problem with the temperature sensor. Wondering how yours displays the transmission temperature mine displays the engine coolant temperature
Received 2,827 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
What dash is that? Trans temp and RPM on the display? Somethings wrong here...
Hey guys,
here a short video
https://youtu.be/xtalm1m34Vk
here a short video
It doesn't work with a facelift! Only PreFacelift.
Then you can see things like rpm counter, throttle position and transmission oil temperature in the display.
Hidden menu
How do you find this hidden menu?
This is a hidden AMG menu. You can code this in all PreFacelift cars.
Then you can see things like rpm counter, throttle position and transmission oil temperature in the display.[/QUOTE]
I have a Pre Facelift car with a retrofitted Facelift cluster. Can the hidden AMG be coded on my car? Would love to have the trans temp on my cluster!
