C63 AMG (W204) 2008 - 2015
Code P374A
Old Jul 9, 2020 | 07:10 PM
tdk930s's Avatar
2011 C63 P31 LSD
Code P374A
Hi everyone
I wonder anyone one has this code before ? What happened to me is right after i have a shop guy changed my transmission fluid, i felt the car will jerk a little when i switch from difference mode while the car stand still. and i though that is normal for the new fluid. Today i use a OBD2 scanner to scan the car ,it has a P374A code comes out and it can"t be remove. i wonder could it be the fluid over or under filled to cause that code comes out ?
Please advice..
Old Jul 9, 2020 | 07:40 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I’ve had it appear a bunch of times.
https://mbworld.org/forums/c63-amg-w...nsmission.html
https://mbworld.org/forums/c63-amg-w...-problems.html
I still have it today, apparently it’s permanent at this point. Never got a conclusive answer but car’s been running great for years so I’m not worried about it.
Old Jul 9, 2020 | 07:52 PM
tdk930s's Avatar
2011 C63 P31 LSD
So you think the little jerk is fine when i switched through the modes (from M to C ) ?
cause this is the first time i have changed the transmission fluid (65000 miles)
Old Jul 9, 2020 | 08:05 PM
BLKROKT's Avatar
I never got a jerk from changing the transmission selector. Of course it’s also been exclusively in Manual for the past 4 years so maybe I wouldn’t know. Not going to try either.
Old Jul 9, 2020 | 08:24 PM
RandyMarsh's Avatar
2012 C63 AMG Coupe
can you permanently keep it in manual? or do you mean you just instantly pop it into S->S+>M as soon as you fire it up? Id love to know if there was a way to be in permanent M mode
As to the OP - occasionally when i pop it into S>S+>M i notice the car makes a tiny movement, and a little noise, has to be very quiet to notice. I definitely wouldnt call it a jerk and I assumed it was normal when switching between modes.
Old Sep 17, 2025 | 03:19 PM
Rocco Russo's Avatar
Hey, sorry to revive an old thread, but did you ever get this sorted? I have this code and P0736 which on my Autel shows as a cam sensor issue, but on my cheap generic scanner and everywhere I search it’s an incorrect reverse gear ratio.
Getting a faint steady whining noise when my trans fluid warms up, which increases & decreases in conjunction with engine’s rpm.
