C63 AMG (W204) 2008 - 2015
Paddle shifters in S+ mode
Old Aug 17, 2020 | 12:13 AM
CheckOrHold's Avatar
2019 C43 (SOLD) & 2012 C63 P31
I've noticed when driving in 'automatic' modes that when the paddle shifters are used it selects a gear and appears to prevent the car from shifting to a higher gear than selected. I'm curious if anyone could explain exactly what's going on and the purpose of this.
The reason I ask is that for roll racing I have the issue of the car not staying in 2nd or 3rd gear long enough before the race starts, making it severely lag having to downshift before it gets going. I would prefer automatic mode because the car shifts at the perfect RPMs versus me always short shifting and losing a lot of that momentum from the extra torque it has at the low end. If the car will shift past the locked gear when reaching like 7K+ rpm, then I believe this is the solution to that problem. I just don't really want to test and find out if the car will shift past that gear set to be locked when in automatic mode.
Old Aug 17, 2020 | 01:41 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Try this in S+, use the paddles to put it in the roll gear you want then as you take off pull and hold the + paddle and it should go into D (full automatic).
It shouldn't upshift as you pull the paddle because the engine will be under load accelerating hard and hopefully will upshift at your perfect rpms.
Old Aug 17, 2020 | 01:56 AM
Mort's Avatar
The car will shift up at redline.
Old Aug 17, 2020 | 11:34 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
IF you do what Cwagon said, the car will shift up at redline. However, if you put it into 2nd and stand on it and don't shift up, the car will accelerate until the engine hits redline, and then it'll bounce off the rev limiter and make you feel like a fool. I can't tell you how I know that.
Crap - that is indeed only when in M mode. I stand corrected.
Old Aug 17, 2020 | 11:38 PM
roadtalontsi's Avatar
10 C six trizzle
No it only bounces off the rev limiter in Manual mode where you are in full control. In C E S S+ W etc.... it will upshift automatically at redline regardless of what gear you capped it out on.
Old Aug 18, 2020 | 09:47 PM
skullbox15's Avatar
2014 C63
Correct
Old Aug 18, 2020 | 11:40 PM
Pwhitty's Avatar
2009 C63 AMG
While driving hold down on the left paddle. This will downshift the car to the lowest possible gear without redlining. From there let the car do the work and do not touch the paddles until your are finished. As previously stated, the car will shift at redline as you go through the gears. I have found that the car lags when trying to shift manually.
Old Aug 19, 2020 | 12:18 AM
Yeah, I've known about that. That initial downshift is really slow for roll racing. Better to start in 2nd or 3rd, depending on speed.
Old Aug 19, 2020 | 03:36 AM
Cwagon's Avatar
That is what people are saying.
Just put into the gear you want to start your roll in using the paddles in C, S or S+ (but not in Manual mode).
And if say you have it running in 2 it will still shift up when it redlines regardless.
Old Aug 20, 2020 | 04:26 AM
DRBC43AMG's Avatar
Now what is this E position? I don't have it in my 2013 coupe, just the C, S, S+ and M
Old Aug 20, 2020 | 03:43 PM
skullbox15's Avatar
2014 C63
None of us have that on a C63... that must be for other models
Old Jul 10, 2021 | 03:38 AM
Pyromaniak's Avatar
W163 S210
I can make on egs52 no upshift in redline
