C63 AMG (W204) 2008 - 2015
Oil fill with cooler drain?
Old Sep 12, 2020 | 10:10 PM
aguita's Avatar
AMG
So I changed my oil and drained the cooler for over 1 hour, I filled the car initially with 9.2 and after checking the oil It was low, so I added another qt slowly until it showed on the 3rd tab.
does this sounds ok? 10 qts??
Old Sep 12, 2020 | 10:57 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
Follow the manual. I believe it says start the car until its up to temp then let the car sit for 5 minutes before checking. If you do it any other way you'll get inaccurate readings.
Old Sep 13, 2020 | 06:16 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
As go team said you need to run the engine before checking as filling the oil pan won't have the oil just run into the oil coolers as the piping goes up and down.
Old Sep 13, 2020 | 08:27 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
As others have said, check it as per the manual, 10 sounds a bit high, I have never gotten that much in mine even with an oil cooler drain. The FCP kit comes with 9 liters and I usually get about 8 liters in it and I run an additive, so usually 2 cans of that which is 300 ml each, so total I get 9 liters in it or just a little shy of 9.
