C63 AMG (W204) 2008 - 2015
Part number for door lock motor?
Old Oct 3, 2020 | 10:49 PM
khabel's Avatar
c63
Does anyone have the part number for the motor/vacuum actuator thing that the lock pin connects to?
Old Oct 4, 2020 | 11:36 PM
roadtalontsi's Avatar
10 C six trizzle
whats your vin?
Old Oct 5, 2020 | 03:15 AM
khabel's Avatar
c63
WDD2040772F230430
I had a look on the link above but I must be blind as I couldn't find anything
Old Oct 5, 2020 | 02:08 PM
TPete19's Avatar
2010 C63 AMG, 2010 GLK350
Is that a picture from inside your door? If so, the OEM has been replaced by a cheap aftermarket actuator. I've done that same thing previously and it doesn't last long.
See this post: https://mbworld.org/forums/c-class-w...uator-fix.html
Doing the OEM job is easy, but does require drilling out and replacing some rivets on the inner door skin.
Here's the actuator for the driver door at FCP Euro. I decided that this is a part that will likely need replacement again, so the FCP's replacement policy seemed like a good option. https://www.fcpeuro.com/products/mer...mer-2047201535
And a DIY for doing the real fix: https://mbworld.org/forums/c-class-w...-actuator.html
Old Oct 5, 2020 | 08:12 PM
khabel's Avatar
c63
well shiiiiit
Thanks for the help
Old Oct 5, 2020 | 08:42 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
The OEM lock actuator is mounted on the other side of the inner panel on the actual door frame. That is 100% a hack job.
Old Oct 5, 2020 | 10:58 PM
10 C six trizzle
yep that's not oem at all. Here's what you need. new latch assembly with cover. I'm assuming you'll need a new lock rod too, possibly need wiring harness since they chopped your stuff up. good luck bud!
left front (driver's for usa)
2047201735 2047232708
left lock rod
2047231939
2 rivets for some covering you may or may not need.
0009910037
10 rivets for door card
0049902897
left front door harness 1
2044400305
left front door harness 2
2045402510
Old Oct 6, 2020 | 04:24 AM
khabel's Avatar
c63
left lock rod
2047231939
0009910037
0049902897
2044400305
2045402510
There is a rubber grommet that the locking rod is meant to run through as it passes through the door skin, any idea the part number of that?
Thanks.
Old Oct 6, 2020 | 08:51 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
No grommet. The lock rod has a bend to clear the hole.
Old Oct 6, 2020 | 10:30 PM
khabel's Avatar
c63
This pic is from a different forum thread and I have circled the item in yellow
Old Oct 6, 2020 | 11:07 PM
10 C six trizzle
parts picture shows a big boot that comes with the lock rod for part 2047231939
you'll probably need to transfer the knob on the very end though, that's a separate number 12376600229051
Old Oct 7, 2020 | 04:04 AM
khabel's Avatar
c63
Awesome, thanks
Old Oct 7, 2020 | 11:17 AM
TPete19's Avatar
Totally forgot about this video. I found this to be extremely helpful when I replaced mine.
Old Oct 7, 2020 | 12:09 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
My bad, I forgot what it looked like before I gutted everything.
