C63 AMG (W204) 2008 - 2015
C63 track alignment
Old Oct 12, 2020 | 08:24 PM
eschow's Avatar
W204 C63
C63 track alignment
What are all the track guys running for alignment specs? Trying to find the optimal specs for our cars.
Currently I'm at:
Front:
-2.5 deg camber
.15 deg toe
11.5 deg caster
Rear:
-2.5deg camber
.15 deg toe
Old Oct 12, 2020 | 10:03 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Less rear camber than front. It’ll allow the car to rotate a bit better out of corners. I run -3.5F/-2.5R and it seems to work for me.
Old Oct 12, 2020 | 10:12 PM
roadtalontsi's Avatar
10 C six trizzle
For track use only, I'd definitely toe out the front end probably 15 minutes out on each side rather than in. Lot's of under steer with toe set in for factory spec. Only cured with big power to make the car rotate. Maybe bigger tires in the front end could help too.
Old Oct 13, 2020 | 01:28 PM
The Machinist's Avatar
11’ C63 AMG; D2 Audi A8; 15’ Golf TDi; 97’ F350PSD; B6 Audi S4; D1 Audi V8; A2 VW GTi
Are these specs in decimal degrees or minutes/seconds?
.15 degrees = 9 minutes of a degree.
Old Oct 13, 2020 | 03:47 PM
BLKROKT's Avatar
I run 0.05” positive toe front and 0.10” positive toe rear
Old Oct 13, 2020 | 06:12 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
The ideal setup depends on a number of factors, including the tires, bushings, the track itself and ultimately how you want the car to handle. On the C63, I'd start with -3.0 to -3.5 camber and zero toe at the front, and -2.5 to -3.0 camber and 1/8" toe-in on the rear and make fine adjustments from there.
