C63 AMG (W204) 2008 - 2015
weistec idle pulley bearing number??
Old Nov 29, 2020 | 01:25 PM
ertech's Avatar
mercedes 71 280sl. Porsche 930 . Ducati mh900 and ps1000
hi guys need a new bearing for my weistec idle pulley , I think that bearing was replaced in the past so not sure it has the right one.
anyone know the skf part number?
thanks
Old Nov 29, 2020 | 01:59 PM
The Machinist's Avatar
11’ C63 AMG; D2 Audi A8; 15’ Golf TDi; 97’ F350PSD; B6 Audi S4; D1 Audi V8; A2 VW GTi
The part numbers will be more or less the same. Bearings are numbered the same pretty much with the exception of their prefixes and suffixes. All that would mean are the types of shielding or sealing that they have.
In other words, a 6208 will be the same bearing regardless of who made it.
I don’t have a set of the weistec pulleys, so I can’t tell you what they used.
Pretty much all you need are the dimensions of the bearing- OD, ID, and Width, then to cross reference. They are single row deep groove ball bearings.
With regard for sealing arrangements, you want sealed (as opposed to shielded or open) ones rated for high speed. The difference is how tightly the seal fits around the thing it’s sealing.
High speed bearings have a loose fit to allow for heat expansion.
I would avoid ceramic bearings as they don’t like impact or vibration very much.
Pretty much any Japanese made or German made bearing is a good bet. ***, Nachii, and INA are also good manufacturers.
The reason these don’t last is because bearings are meant to work in pairs. Single row deep groove ball bearings don’t deal with angular moment of inertia very well. In any case they will not last forever because of this.
So if someone could design these pulleys to use pairs of bearings instead of singles, problem over. Something to think about perhaps. If only I had a CNC lathe.
Old Nov 29, 2020 | 09:44 PM
ertech's Avatar
its 6203-2RS bearing in case someone needs it
thanks
