Defective fuel injectors again, gas
Has anyone else had a problem like this, and if so, have you found a cure to my problem? Is there a spray in liner inside the tank from MB that could be disintegrating slowly like Ford diesel trucks had problems with?? I've never had an MB with ongoing unreliability problems like this one has! This car is jinxed, WHY?? Thank you for any suggestions for my problem!
What happens I was told is that the spikes of higher voltages going to the injectors can warm up the solenoid, making it grow and bind up causing the injector to be stuck wide open! NOT GOOD for sure. A new ECU from Mercedes I was quoted recently is $1570 plus sales tax, then you have to pay to get it programmed for your VIN and other details/options on your car. This has nothing to do with the ECU getting defective signals in from sensors on the engine!
Hope this helps others that may have the same problems I was having for so long making my car very unreliable and with no warnings before it happens on the road!
