C63 AMG (W204) 2008 - 2015
Will these W205 wheels fit on my W204?
Old Mar 2, 2021 | 03:20 PM
A///MG_Power's Avatar
2012 Mercedes C63 AMG
hi,
I am considering buying a set of OEM AMG Silver Forged Cross Spoke Wheels (19x9 ET37, 19x10 ET47) / Goodyear F1 Asymmetric Tires (255/35/19, 285/30/19) from a W205 C63 coupe on here but am wondering if it will fit my stock 2012 W204 non-P31 C63 (esp concerned about the rear). Again, I am not lowered.
willtheyfit.com states that in the rear the inner room will be 5.7mm closer to the strut and the outer rim will poke 19.7mm compared to stock.
i know search is my friend but I couldn’t find anything specific on the w205 coupe fitment on w204 sedan when I searched. Maybe I’m searching for the wrong terms but would like to consult the forum’s expertise. Thanks in advance.
please note: I’m open to sedan fitment for these wheels so don’t hesitate to reach out if you have a set! Thanks.
Old Mar 2, 2021 | 04:04 PM
blurred's Avatar
2013 C63 P31
Those are not OEM wheel sizes for the w205 c63, they are from a CLS63 and do not fit
Old Mar 2, 2021 | 04:11 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
They definitely won't fit with the supplied tires.
Not sure on those ET's as they don't come up as W205 fitment.
Mercedes-Benz C-Class AMG 2017 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com (wheel-size.com)
Most guys running a flush fitment in similar size have 19x9 ET40 245/35 front and 19x10 ET50 265/30 rear.
Some run 275 on rear and put up with an occasional rub over big dips or rises or carrying passengers.
https://mbworld.org/forums/c63-amg-w...ml#post7026160
https://mbworld.org/forums/c63-amg-w...ml#post7099873
Old Mar 5, 2021 | 01:50 AM
Thanks for your input here. This is very helpful. The wheels are from a CLS 63.
Not to go off tangent, but if hypothetically speaking there was a set from a non-S W205 C63 Coupe which were 19x9 et 25 front and 19x10.5 et 57 rear, then they would not fit our W204, right?
Thank you for your input here.
Old Mar 5, 2021 | 02:50 AM
Cohen63's Avatar
2012 C63 AMG P31
In my opinion the absolute maximum that can fit under stock rear W204 C63 arches would be a 19x10 et 54 with a 275/30/19 tire, anything wider will rub especially if lowered. This is speaking specifically about 19 inch wheels only
OEM W205 C63 Coupe wheels in both 18 and 19 inch have much more aggressive widths and offsets than both W205 sedan and W204 sedan because of the wider body and wider tracks therefore they will not fit a W204 sedan. I would rather fit OEM wheels from the W205 C63/C63S sedan because those widths and offsets work perfectly on a W204 C63 sedan and coupe.
Old Mar 5, 2021 | 09:35 AM
blurred's Avatar
2013 C63 P31
You need the C63s sedan wheels like most of us have upgraded to, they fit perfectly
those are 19x8.5 +38 front and 19*9.5 +56 rear
