HELP! P0455 CODE (12’ C63 COUPE)
Check engine light came on for first time since buying the car, I took it up to my local shop and had them pull the code (P0455). Car has an aftermarket burble tune along with charcoal and resonantly delete. Not sure if the delete and tune has anything to do with it. After doing some research I see a lot of people experiencing the same issue with the P0455 code. I don’t believe it’s the gas cap because the seal seems to be fully intact and I always make sure it’s locked in tight. Hoping to figure this out and diy fix it before going to Mercedes and donating my kidney.
Scanner reads “Major Leak in Purge System/Hose in System Not Connected or Filler Cap Open (P0455)”
PS Sorry in advance if this is an exhausted topic!
Search for 'pcv c63' | FCP Euro
