C63 AMG (W204) 2008 - 2015
C63 alignment settings for maximum tire life
Old May 10, 2021 | 03:54 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Originally Posted by hachiroku
to each his own...my car is at 0 toe all around and its exactly how i expect all of my vehicles to handle. turn in and oversteer are very different. toe out increases turn in, but that is only if you've increased toe to do so.
Acceleration turns your 0 toe (rear) to toe out on an independent suspension car.
Most of the time it’s done on a corner exit and can result to oversteering sooner than needed.
Old May 10, 2021 | 04:02 PM
Originally Posted by Jasonoff
looks like I'm getting back into it.
Old May 10, 2021 | 04:30 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
turn in and oversteer are very different...anyway i'm no longer interested in the back and forth.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old May 10, 2021 | 05:26 PM
OP.
If you don't want to end up like that guy below, make sure you have a little toe in at the rear. I would stay with the specs recommended by Mercedes when it come to toe.
Old May 11, 2021 | 01:30 PM
djr48312's Avatar
2009 c63
I can understand that in forward motion and under acceleration there will be a small amount of deflection resulting in a "toe out" under load. So some minimal toe in is to be considered to compensate.
I still don't think we have to suffer having the inner 1-2" of tire wear 70% faster than the rest of the tire.
