C63 AMG (W204) 2008 - 2015
Aftermarket Wheel Problem
Old May 6, 2021 | 02:26 PM
Mean63AMG's Avatar
W205 C63s Coupe
I've recently been trying to order a set of Niche Misano for my c63. I've looked at 19 x 8.5 for the front and 19 x 9.5 in the rears. However the offset i have no idea what size I need. Two different places have told me these do not fit on the w204 63 but I have seen many w204s with the same wheels. Can anyone help me with this? I have stock suspension and I run 265 rears and 245 front. Thank you.
Old May 6, 2021 | 03:34 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
They will fit I have the same wheels.
You can run two different offset in the front (I had both) +34 will rub with 245 and looks little too aggressive for my taste.
I switched to +42 offset and does not rub with 245 but might when lowered.
For the rear you can only run +50 offset and 265 will work just fine.
Get them off ebay.
Front +42
Rear +50
Old May 6, 2021 | 03:46 PM
Mean63AMG's Avatar
W205 C63s Coupe
Get them off ebay.
Front +42
Rear +50
I'm gonna go ahead and order them. Thank you for the help!
Old May 6, 2021 | 03:47 PM
Just make sure the part number in the eBay listing match the list I posted.
By the way I have the +34's still in my garage in case you want them. (one has a little damage)
Old May 6, 2021 | 06:09 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I have standard suspension on 2013PP estate and run 8.5" ET38 front with 245 PS4s and no problems with rubbing.
Rears are 9.5" ET56 with 3mm spacer (now ET53) running 275 PS4s and no rubbing.
