C63 AMG (W204) 2008 - 2015
ML63 Random Misfire all cylinders
Old Jul 9, 2021 | 04:03 AM
kwantum's Avatar
Ml63
Exclamation ML63 Random Misfire all cylinders
My 2007 ML63 M156 engine is down with random misfire code code P0300, other codes include:
P0191- fuel rail pressure sensor circuit range/ performance
P0304-cylinder 4 misfire
P0301-cylinder 1 misfire
P0302-cylinder 2 misfire
P0307-cylinder 7 misfire
Basically there are misfire codes for all cylinders
there is a code P0661 not sure what its for..
I also noticed when i start the car it shakes terribly and the driver side exhaust blows out cold air only (Right hand drive).
I have since changed the spark plugs, swapped out the coils, even checked the timing of the cams and still get the misfires..
anyone to point me in the right direction
Old Jul 9, 2021 | 10:48 AM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
I would start with the fuel pressure potential issue first. Check your rail pressures. For me when I have had the same issue a fresh set of primary o2 sensors fixed the problem but I have headers. Common issue.
Old Jul 9, 2021 | 04:34 PM
kwantum's Avatar
Ml63
did you have any error codes to show that your O2 sensors had gone out?.
Old Jul 9, 2021 | 10:09 PM
AMGonFire's Avatar
same codes as you minus the fuel pressure code that was it.
Old Jul 12, 2021 | 01:57 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if it's not the ignition coils it's the oxygen sensors. replace both of they're up in age.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Jul 12, 2021 | 03:52 AM
kwantum's Avatar
Ml63
will give the O2 sensors a try.
