C63 AMG (W204) 2008 - 2015
Damaged wiring to camshaft position sensor
Old Jul 16, 2021 | 04:00 PM
markov77's Avatar
2014 C63 AMG 507
While troubleshooting an ongoing CEL related to a high circuit error code I finally discovered the wiring to the sensor is damaged. Does anyone know the best course of action to fix this? Picture below.
Old Jul 16, 2021 | 04:05 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
If it was me I would replace a few inches of that wire, solder in a new piece and use water proof heat shrink tube over it then I would extract the other 2 pins and slide a larger piece of waterprood headshrink over all 3 wires to seal and overlap old sheath then put the connector back on. You could also just tape it well to cover all 3 wires, but you want to seal the individual wire well and solder the new piece in same gauge.
Old Jul 16, 2021 | 04:33 PM
markov77's Avatar
2014 C63 AMG 507
Thank you, I will give this a go.
Old Jul 16, 2021 | 04:37 PM
Top Answer: 1
key is good connections and then seal it well so moisture cannot get in and cause issues in the future - good luck!
