Engine install compatibility
Possibly 2012 C63
Hello,
New here and have spent a few hours reading threads before posting and I’m still not 100%.
My car history is with Mazda Rotary and Jaguars, all of which I’ve done all my own work and the understand pain working on cars well.
I have the opportunity to buy an immaculate body & interior 2012 C63 at an awesome price, awesome price due to the sump being ravaged by a rock, engine is toast.
I have a few donor engine options, one for the matching year, one from 2014 out of a 507 edition incl trans, harness & ecu.
Would the 2014 be a straight drop in option?
All the reading I have done would point to yes but just after some clarity on this.
Cheers!
Cheers!
Possibly 2012 C63
The 2014 is definitely a W204 so it going in should be ok, I think next step would be to check ecu compatibility between harnesses as if I only need to put the motor and ecu in it should go.
Do you know the Mercedes have security programmed components like my Mazda? If I change the ECU in the Mazda it will turn on but won’t start without reprogramming another module to the new ECU, I’ll start looking at this now.
Researching ASAP as I don’t know how long that motor will be around, might call Mercedes and see whether they give me an honest answer.
