C63 AMG (W204) 2008 - 2015
Transmission issue?
Old Aug 22, 2021 | 09:38 PM
Backsetter's Avatar
'86 Buick Grand National, '99 Honda CRV w/300,000 miles!
Transmission issue?
Occasionally when I back out of my driveway and shift my C63s into drive my engine will rev up to 2,500-3,000 before the car starts to move. Has anyone experienced this? Solutions/suggestions?
Thanks!
Old Aug 22, 2021 | 11:49 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Thanks!
Mine also does the same in reverse when cold.
My driveway is uphill and doesn't matter which way around my car is, it sometimes flares when cold.
This happens especially if I have to stop for pedestrians while still on the slope.
This does not happen when engine/trans is hot (normal temp).
Old Aug 22, 2021 | 11:52 PM
Backsetter's Avatar
Thanks for your response. My car is at the dealership now. They’re “researching” the issue so I thought I’d help them out.
Old Aug 23, 2021 | 07:20 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Pretty normal there are a few other threads on it and both of mine have done it to some degree, I also find if you come to a complete full stop before putting it in drive it does it much less often but seems it is a bit slow to engage the clutch when cold especially when going from R to D, once warmed up I have never experienced it.
Old Aug 23, 2021 | 09:42 AM
Music City Benz's Avatar
2010 Mercedes-Benz C63 AMG
Mine does that every now and then as well.
Old Aug 23, 2021 | 12:20 PM
Thrilla's Avatar
Veteran: Army
2014 C63 AMG 507 sedan
I notice this too every once in a while. Usually, when I haven’t driven it for a few days.
Old Aug 23, 2021 | 01:13 PM
lemonstand's Avatar
2014 C63 507 Edition Sedan - Mars Red
normal. Mine does the same. Do a search here on the forums and you’ll find the same.
Old Aug 23, 2021 | 06:46 PM
rovis77's Avatar
C63 AMG
Can you tell me what symptoms does your car has?
Old Aug 23, 2021 | 08:06 PM
Cwagon's Avatar
Just out of interest are people experiencing this problem with both transmissions or just the later multi clutch FL version?
Old Aug 23, 2021 | 10:56 PM
roadtalontsi's Avatar
10 C six trizzle
its only facelift. Torque converters will be smooth as always.
Old Aug 23, 2021 | 11:51 PM
Cwagon's Avatar
Thanks, as I thought.
Old Aug 24, 2021 | 11:52 AM
rovis77's Avatar
C63 AMG
The C63 AMG 2013 facelift doesn´t have a torque converter?. What difference does this make with the prefacelift version?
Old Aug 24, 2021 | 02:25 PM
deadlyvt's Avatar
2010 C63 AMG
exactly so in the prefacelift it doesn’t do this. This is unique to the mct transmission
Old Aug 24, 2021 | 03:11 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
No. The pre-facelift C63 uses a standard torque converter. The face-lift C63 (2012+) uses a wet clutch immersed in oil instead of a torque converter that allows for quicker shifts and mechanical coupling of the engine to the wheels (so when you lift off you get the same engine braking that you would on a car with a manual). It still uses planetary gear sets and disc packs, with a wet clutch replacing the torque converter. See https://media.daimler.com/marsMediaS...ml?oid=9904482.
Old Aug 24, 2021 | 09:43 PM
rovis77's Avatar
C63 AMG
Wowe I did not knew this. Which transmission is better, the prefacelift version or the newer one. Which one is smoother?
Old Aug 24, 2021 | 09:46 PM
rovis77's Avatar
C63 AMG
Where can I find more info about the one that the OP reports?. Does this also happen to you?
Old Aug 24, 2021 | 10:13 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I am now convinced this is a troll account...
Old Aug 25, 2021 | 08:51 AM
Diabolis's Avatar
@rovis77 - please learn how to use Google. Thanks!
Old Aug 25, 2021 | 10:02 AM
rovis77's Avatar
C63 AMG
No dude, I am not a troll. I just bought my C63 two months ago and I am new to this so that´s why I come to this forum to ask questions
