Electrical Gremlins
120XXX kms on the odometer
So in the past month or so my battery light is coming on quite regularly. I replaced the battery and it disappeared. Bought a battery locally and as far as the specs were concerned it exceeded OEM for about 250$
Now a few weeks later battery light came on again and so I replaced the alternator. All seemed good for a day or two and now the battery light is back.
I watch my voltage on my display as I drive and on startup I hover at 12.3-12.4 and over the span of 15 minutes ill dip below 11.8. Once I shut the car off and I turn it back on it starts to charge over the span of another 15 minutes or so ill see it reach 13.2 - 13.3 (Maybe higher my drives just generally aren't that long)
I tried to charge my battery to full to see if that may rectify the issue. No dice it never charges on a cold start. I took a peak at my connector on the alternator thinking maybe that was an issue and seen no problems but cleaned it anyway. The only thing I did notice is that the alternator has 2 pins but I only have 1 wire going to it (plus the main)
Any help would be greatly appreciated.
Threw in a battery from my truck (lead acid not agm) to see if maybe that would change my readings but still only 12.1-12.4 volts at the battery.
Starting to think circuitry somewhere is wrong, any relays or electrical components associated with the charging system that may cause this?
Any help ladies and gents!
