Alignment Changing After Driving
After the alignment the steering wheel was still off center. I was lazy and assumed it was due to the bix box being lazy or not knowing what they were doing. So I had an alignment scheduled with my indy that I typically use for all other work. They aligned the car and centered the wheel. It was fine for the first day and then the steering wheel slowly moved off center again the more I drove until it was right back to where it had been before the work. Has anyone ever run into a problem like this in the past? Its like something is coming loose and allowing the alignment to move after the proceedure is complete. One thing to note is that I am lowered on Bilstein PSS10's with the KMAC rear bushing kit.
Any help is appreciated!
I do have a knocking coming from the front right suspension area. I had previously thought that the strut bearings were going bad and needed replaced. But it might make sense that its the lower control arm as well.
Question is, are there other options instead of KMAC in the rear? Has anyone else had issues with their KMAC bushings failing after so many miles? I want to get the camber back in a good spot but I dont know the best path to go down at this point (arms vs bushings, etc.)
The actual K-MAC design - is for both “Front Camber and Caster” - along with “Rear Camber and Extra Toe” FOR MODELS WHERE NO OEM ADJUSTMENT EXISTS.
HAS BEEN IN PRODUCTION SINCE 1993. Over 30 years - well and truly proven. (Not only day to day commuting but all out heavy V8 Competition racing) !
WITH ALL THE FEATURES - Designed to fit without time consuming need to remove control arms. Precise easily accessible single wrench adjustment. ULTIMATE - direct on alignment rack UNDER LOAD.
FOR LONG TERM MAINTENANCE FREE OPERATION. IT’S BASIC (AS HIGHLIGHTED ON INSTRUCTION SHEET) - AFTER “INITIAL ALIGNMENT AND CAMBER BEING SET. CORRECT TORQUE SETTINGS IS APPLIED ALLOWING FULL CLAMPING TO TAKE PLACE. THEN APPLYING THE K-MAC FAIL SAFE LOCK SYSTEM.
AUDI to VOLVO - K-MAC Experience Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
AUDI to VOLVO - Experience Of Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
