C63 AMG (W204) 2008 - 2015
Black Series Questions
Old Oct 10, 2021 | 11:19 PM
BocaExotic's Avatar
2014 C63 507, 2012 C63 P31, 2018 S63
Hi all,
I'm possibly buying a 12 C63 Black Series and I got a PPI done on the car and it seems to have a resonator delete... Is the exhaust on the BS any different from the ones on your normal C63? Would it be hard to find the original part and revert it back to stock?
Old Oct 11, 2021 | 08:53 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Are you sure it is the resonator as the secondary cat is the more normal thing to remove the resonator is not typically what you want to remove. I believe both are interchangeable, the resonator which is part of the right rear section pipes including mufflers has a different part number but is just listed as muffler without tips as the BS has no tips and that is likely the only difference. Certainly a regular resonator will weld in fine as the size is the same, but not sure what is inside the resonator is the same as stock the BS is louder than the standard C63 so something is different inside I think somewhere.
