C63 AMG (W204) 2008 - 2015
Problem unsolved
Old Nov 21, 2021 | 05:28 AM
xxxscimitarxxx's Avatar
C63 AMG 2009
Problem unsolved
After a lot of weeks with C63 specialist company an issue remains unsolved
Weistec stage 2 2009 C63
Car car idles and drives fine if I just plod it about all the way up to and we’ll into motorway driving speeds
But punch it in C and it bogs down!!! won’t Rev past 4 grand… revved at park or neutral it won’t go past 4 grand
Interestingly punch it in S and it bogs down and it changes to C
Same in M in any gear… punch it and it bogs and changes to C
It has thrown NO codes … Star Tech scanner confirms
no gearbox codes… been checked over by gbox specialists…nothing wrong with the box
had a fresh Weistec map installed…. No change
So No Codes!!! So assume not gearbox or trans module…. Assume not ecu in general
my last thoughts… traction control… but effectively an 09 does not have traction control in the same sense of what later cars hav… an 09 does not have launch control
Anyone else got any ideas
you can discount battery, injectors, coils, fuel, fuel pump, throttle bodies, SC belt slip, vacuum leaks
Old Nov 21, 2021 | 02:31 PM
INS1GNIA's Avatar
'13 C63 AMG P31
Could always try a different tune. Maybe not the most cost efficient way, but that would be my guess.
Old Nov 21, 2021 | 03:48 PM
YYCStage3's Avatar
2012 C63 AMG P31, Stage 3 Weistec
I had an issue with my initial Weistec stage 3 tune. The car wouldn't rev up, just basically went into limp mode, no codes. The ECU was sent back to them and they "adjusted it" without any real explanation, which ultimately did fix the issue.
I'm with INS1GNIA, could be a tuning problem. A platform like HP tuners would be helpful to do some logging and see what's really going on, or have more information to review.
Old Nov 21, 2021 | 08:09 PM
Panzerbiscuit's Avatar
C63 AMG
Agreed. Data logging will be able to assist with diagnosing any issues you have, or at least help you rule out what isn't causing you strife. Hachiroku can provide you with a second tune, just to rule out any tuning issues as the culprit of your problems
Old Nov 21, 2021 | 08:58 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nobody knows what your “stage” number means. People throw it around and it usually means 7 or 8 different things. Post up your mods so someone can help you understand what might be going on.
(by the way, around here Weistec “stages” usually refer to Stage 1, 2 or 3 supercharged cars)
Old Nov 21, 2021 | 10:41 PM
roadtalontsi's Avatar
10 C six trizzle
park and neutral if vehicle speed is a standstill has a rev limit at 4k. that is normal. Does it do the same thing in dyno mode?
a stage 2 weistec car should be pretty solid. I'm sure these days the out of the box tunes from them are pretty weak.
Old Nov 22, 2021 | 01:30 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
flash back to stock if you have a handheld to see if it's the tune. if its the tune reach back out to your tuner for an updated tune. if you identify that the tune is the issue and are looking for a end to end custom tune for your setup, feel free to reach out. we have many customers who previously had a weistec tune and felt it was barely any better than the factory tune.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 22, 2021 | 02:37 PM
blurred's Avatar
2013 C63 P31
In your older thread someone told you to replace the MAP sensor... did you?
Do you have traction control fully off or in Dyno mode to test? Have you reset the ecu to remove all trims and tested?
