C63 AMG (W204) 2008 - 2015
command unit
Old Nov 22, 2021 | 02:12 PM
huntcgray's Avatar
2010 mbz c63 amg, 2008 mbz s550 base
command unit
command screen doesn't pop up any longer.. everything still works just fine.. well ateast what I'm able to access from the steering wheel and the buttons below. so basically just changing the radio station and the volume and anyone been able to figure out why this happens on a different thread? I saw it said re seating fuses 11 and 26 in the fuse box in the engine bay. does the trick for a temporary fix? anyone have a permanent one? I haven't tried the temporary yet. I just saw that moment ago
Old Nov 24, 2021 | 04:44 AM
RadioguiyBill's Avatar
280SL
If you have the code disconnect the battery for about 1/2 hour. Then set the radio up with the code
