Looking to purchase 2010 C63 with no history - what all to get completed?
What else should 12yr old / 40,000 miles C63 require/check at this point that I can have them complete while they are under the hood?
Thank you in advance.
40k service on these cars is:
Service B (oil change, cabin filter, air filters - some other misc things like lube of the sun roof, door locks, and wiper blades)
Transmission service
Rear diff service
I would check to see if those have been included or already done.
Long term, the camshaft adjuster plates will wear out and the PCV valve, idler pulleys, and motor mounts will need to be changed around 60-80k depending on conditions and driving habits. Some people replace the fuel injectors as well due to an issue where they may get stuck open and flood the cylinder with fuel. I changed mine around 65k.
Plugs are supposed to be done at 60k but mine looked fine at that mileage, I did them anyways.
