Question about shift shock of MCT transmission.
My car is a 2013 W204 C63, and I bought it used.
I recently replaced the valve body with a remanufactured part at a Mercedes-Benz service center, after which I did one more the transmission adaptation.
Most of the shift shock has been resolved, but the shift shock that seems to be pushed from behind while the car is almost stopped in sport mode is still unresolved.
I would like to know if this is a characteristic of this model or if it has not been properly repaired.
More precisely, when the vehicle is decelerating rapidly, the downshift occurs earlier and the phenomenon does not occur.
However, if the vehicle is decelerated slowly, after shifting from 2nd to 1st gear is completed, there is a phenomenon that the vehicle bounces forward.
This doesn't happen in comfort mode, it only happens in sport mode (probably because comfort mode doesn't use 1st gear).
Is this the original characteristic of this model? Or is it a part that needs additional repair?
Thanks in advance.
Thanks in advance.
Otherwise, if you have the programmer to switch back to stock, that would likely help greatly. That's how I diagnosed my issue as being the EC tune.
eightysixtuned (05-18-2022)
12 C63BS Magno Alanite Grey, 22 X3M Brooklyn Grey, 08 BMW E93, 22 Ducati Desert Sled, John Deere 3R
Ya sounds like how my Eurocharged V7 tuned car shifted and was why I removed the tune and didn't tune my 507, had more power and less drivability.
