C63 AMG (W204) 2008 - 2015
Rear indicator not working
Old May 23, 2022 | 07:23 PM
aus c63's Avatar
2011 C63 P31
I can't see that there is any replaceable bulb to fix a rear turn indicator light not working. Am I going to have to replace the entire tail light just to fix this?
Old May 24, 2022 | 05:10 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
check the electrical connection to the taillight as I recall there may have been a recall at some stage to do with shorting in the connector in sedans.
Old May 24, 2022 | 07:17 PM
GRP's Avatar
GRP
2010 C63 and 2018 GLC63s
Poor connectors - had a replacement put in mine - my workshop had them in stock as they do it so often..
I understand that in the USA it was a warranty fix but not here in Aus.
Wiggle the connector about and it will likely work only to fail again and keep failing
Old May 25, 2022 | 07:24 AM
aus c63's Avatar
2011 C63 P31
Thanks guys.
I have checked. There were no recalls for this problem in Aus, as apparently there were elsewhere in the world. I have located a workshop in Perth where I am that are familiar with the problem and they have assured me it will not cost an arm and a leg to fix the issue.
Cheers.
