Wheel size??
Wheel size??
I am currently trying to figure out if 275 would fit in the rears of my car. I have the w204 sedan and the size of my wheels are 19x9.5 with a +50 offset. Im thinking about running Nitto NT05 275/30/R19. I wanna make sure that there would be no rubbing and that they would fit just fine.
You should not rub with that wheel and tire selection. You can run a 10mm spacer on the rear with stock wheels and the poke with those wheel specs should be 10.4 mm.
Here are the specs from Will They Fit : https://www.willtheyfit.com/index.ph...9.5&offset2=50
This is a 19x9.5 +56 with a 275/30/19 Michelin PS4S, no rubbing or issues. Looks like it would be just about ok another 6mm to the outside
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/1080x1440/20210330_071806_capture_1__f2ba41106114e0ffdef767813e75f7f352f4b6a5.jpg)
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
My rears are 19x10 with a +50 offset and I am running MPS4S 275/30-19 on a coupe with the 10mm lower APX (P30) suspension and can confirm there is no rubbing. I don't think the fender clearance is any different on the sedans. Plus, the Michelins run a little wider than the Nittos - a few years ago I ran a couple of sets of NT05s on the Vette track car and had two of the fronts remounted on the C63 when I got a flat on one of the rears. Ran them on the rear of the C63 for about two months including a couple of track sessions (not full days, but certainly enough to show if there was any rubbing under full compression) and a ~50km trip to the airport over not-so-smooth roads with three passengers in the car and a loaded trunk.
