2010 c300 4M can bus
2010 c 300 formatic
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/0512b0f6_21a5_40a6_8925_6ab657164c0f_2a254230a57a82ed4cb7fceca5aae48119f0f698.jpeg)
Can bus faults galore Sorry if I’ve posted this twice. Still figuring out platform
![](https://cimg0.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/f45c6a28_9e37_4b74_b152_8e8538b28cae_39e36b868323c4542e58fc651227637d31ff34e9.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/66f416f6_5e77_4899_b977_7ece0031caf9_029d25e1b94f1e4333770c421d987d0cd5d074e2.jpeg)
![](https://cimg9.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/aada152f_e38f_41e6_b299_a2372be306bc_f266168b10fd22ff72794ed9a9db9fe93fc2a85d.jpeg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/17e3374a_dbbf_4b75_a8aa_ca16019f4bd5_d25b630e7eeb5e14860f4f3fb11dc7b6d9f67ef7.jpeg)
Dash lit up like a Xmas tree, INOP wipers,high beam stalk, turn sig, A/C, fan runs constantly, abs and tire press. Monitor inop and illuminated on gauge cluster. diagnostic with snap on scanner,codes above,
so no signal, no signal, I have not pinned the OBD but had sunroof leak so “ immediately assumed”
low/ hi signal connectors under the passenger front footwell corroded.
I have used these scanners before but without connectivity I can’t check each module. Also that’s the nature of the canbus system. I keep thinking it’s a wire. And I did find two connectors with circuit boards underneath the wet carpet. Just don’t want to throw money at something when I really don’t know all the information yet.
You have a 2010 C300? Then it should be this Forum for C-Class (W204). https://mbworld.org/forums/c-class-w204-83/
