C63 AMG (W204) 2008 - 2015
Power steering triggering ESP ABS
Old Sep 20, 2022 | 02:08 PM
catmandoob's Avatar
'08 C300 4Matic Sport / '11 C63
Hey all, just double checking with something right now.
This just started after I cleared my service codes. The next morning I started the car and as soon as I hit 5mph Power steering stops and ESP, ABS not operable comes up.
I have already ordered power steering res. and fluid but my questions is, does my pump need replaced too? I'm thinking the filter is clogged and the pressure is kicking it into a safe mode turning power steering off but not even sure if this car has a feature like that.
The reason I ask is because I can start the car and idle just fine with power steering going end to end no issue but as soon as I hit 5 mph like I said it kicks off and dash lights up ESP ABS.
The other conundrum is when this happens my blower fan and vets seem to go weird and get stuck mid vent switch, so it blows some out front vents and some our defrost and some out floor but not much t all, seems it gets stuck blowing in dash.
So yeah, the more money I spend to fix **** the more **** seems to be breaking haha
Main direction I'm looking for is the link between steering and ABS ESP.
Or is it my accelerator pedal, I did have a code for it sending an implausible signal. But I reset it and haven't seen it again yet.
Old Sep 20, 2022 | 04:40 PM
dfreret's Avatar
2001 E55 AMG, 2009 C63 AMG
Scan for codes and look for a speed sensor fault to start.
Old Sep 20, 2022 | 09:41 PM
catmandoob's Avatar
Well finally got to pull codes, looks intersting.
code B222500 Steering column module has a malfuntion
5001 Control unit N30 / 4 internal fault
7266 DTR distronic Consequential fault
This should be interesting. Any idea's where to go from here
Old Sep 20, 2022 | 11:04 PM
roadtalontsi's Avatar
10 C six trizzle
Do you have access to a xentry unit. Those are very generic.
Old Sep 21, 2022 | 07:43 AM
catmandoob's Avatar
I do not have access to xentry sadly, however after clearing the codes they haven't returned.
Doing some digging I was thinking in reverse, seems to be my ESP/ABS module that disables power steering. I'll probably try to pull my ESP module off and take a look and clean it. Other than that maybe just a freak coincidence when I used my reader to sort other things and do some resets.
Only other thing I did was the notorious turn the steering rack end to end to try and reset steering angle sensor. Guess I will see how long it stays code free and drives normal.
