C63 AMG (W204) 2008 - 2015
Widebody wheels offset help please....
Old Nov 27, 2022 | 08:31 PM
Cashrolling's Avatar
C63
Hi, what is the highest offset i can clear the inner strut with using a 12 inch wide wheel? Can 19x12 et35 fit?
i did a lot of research but can't find a definite number in the inner clear....
Thanks 🙏
Old Nov 28, 2022 | 12:11 AM
AshBNE's Avatar
2010 c63
Mine were:
front 19x9 et 40
rear 19x11.5 et 30 305
Not sure about highest offset on 12 inch wheel.. I think et35 would be ok but I don't have my car anymore to check clearance
Have you played around with https://www.willtheyfit.com/ ?
Also fyi : https://mbworld.org/forums/c63-amg-w...ml#post7974135
Old Nov 28, 2022 | 08:45 AM
C63
Originally Posted by AshBNE
Mine were:
front 19x9 et 40
I can't find what's the inner clearance, i will eventually get on a lift and measure it, but wanted to get a number first. I know guys fit 19x10 et55, which would equal to 19x12 et30. So to fit et35 i need those extra 5mm.
Anyone with et55 can confirm the extra space or that's the limit for 19x10?
Old Nov 28, 2022 | 04:16 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
If you have wheels on the car now, then try this site.
Old Nov 28, 2022 | 10:52 PM
C63
A lot of people here have 19x10 et55, i would like to ask anyone familiar with that set up how much clear left on the inner side to the strut. Or is et55 the highest offset possible on a w204 C63?
Old Nov 30, 2022 | 11:00 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I’m currently 19x10 ET52. That’s as close to the rear strut as I’m comfortable with but I’m also running quite a lot of neg camber and 295’s which bulge a bit (my 19x8.5 ET45 front rubs on my coilover collars with 255s and 265s).
Am moving to a 12” rear also, maybe wider we’ll see. Haven’t measured yet.
Old Dec 1, 2022 | 10:47 PM
C63
I've done some calculations, I think i will go with a 19x12 et30( that leave me the same inner clearance as a 19x10 et55, which lots of people have no problem with). My tire should be stretched to properly fit and don't rub the inner strut and the outer fender-bumper meet point. So I'm thinking to go with a 305-30-19 to play safe, that should be stressed enuff on a 12inch wheel. From that if i see i have the space my next set will be 315. For the front 19x9 et40 with a 255-35-19. I'm at stock P30 height.
