P0410 ugh what to expect from dealer?
2013 c63 p31
Hi
I have a 2013 c63 p31. I just had b0 service at 61k miles and within 700 miles received the p0410 code.
I have read what this code is and see repair from a few hundred to 7k. I am ok w doing maintenance on cars but some of the photos I see, I am not sure I am up to this task.
Any advice on what to expect appreciated. I have a dealer nearby or an MB repair shop w excellent rep but have never used them. I have only used my dealer thus far bc I only needed routine maintenance. Would a MB shop in general handle this?
Inspect all the vacuum lines for any small cracks. You may have to move/flex them a little to find a crack. I fixed mine with some crazy glue on one of the cracked hoses. This was many years ago and it never returned.
eightysixtuned (01-03-2023)
2013 c63 p31
Mine was here under the front cover which just snaps off upwards (keep hands in same area as you go around the cover as not to crack it)
I used a little crazy glue and lifted the opposite side with a rod while it dried. I intended to buy the part but the repair worked so I kept it.
Cwagon (01-04-2023)
