Rear wheel bearing replacement
Does anyone have the procedure from WIS? Any special tools required? I have a C207, but it should be the same and I haven't gotten a response from that forum. Thanks!
I've done it on my w204 and just remember the only special tool needed was the axle nut socket. As long as you have all your normal torx and e-torx tools, you'll be fine. The hardest part was getting the e-brake stuff back on.
