Part number for broken plastic coolant connector
While doing my cam adjusters I accidentally broke off a plastic connector that joins the small coolant hose from the coolant reservoir to the front of the water pump.
Anybody know what this black plastic piece is called/part number for it?
Thanks!
The connector attached to the coolant host
Close up of connector
Thanks!
Found it:
Part number 156-203-04-75
Gotta buy the whole thermostat housing. The housing comes with the little plastic piece attached. Its a delicate POS, I gotta be more careful
https://classicparts.mbusa.com/oem-p...kit-1562030475
I had this on mine, if you don't want to buy a whole housing. I just removed the housing, drilled out the remaining plastic from the whole, tapped a thread into the hole and screwed in a 90 degree brass hose connector with a bit of blue sealer on the threads, then just put the pipe back on worked a treat and this is prone to snap being plastic when the belt goes so its a bit of a upgrade also
Received 2,842 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I mean, is there a good reason to even keep using that stupid thing? I don’t think there’s any sort of valve in there. I wonder if going forward you’d be better off just tapping the thermostat housing and threading a brass barb fitting in there, use a small worm gear clamp to secure the hose, and call it good forever?
Cwagon (01-21-2023)
