Destroyed pulley bearing
sickSVT (02-15-2023)
Silversun262 (02-15-2023)
2014 C63 507 polar white sedan, 2014 300GLK
Thank you so much Hachiroku for your reply! After much effort and string pulling I was able to obtain a recommendation. It would appear that SFK 203sffst-hyb#1-h701 would be the best recommendation for my Weistec pulleys which use 7 of these size 40mmX12m,mX17mm bearings. The problem now is that these bearings appear to be unobtanium! I have not been able to source them anywhere: I would be most grateful for suggestions and leads on where to look for them.
Best,
Best,
duuder (02-18-2023)
In the five years I've owned mine, I've been through 3 belts and around two or three broken pulleys. I have used three different makes of belt also, dayco, conti and now on a gates.
I just think this a common issue with these engines and no matter what belt or pulleys you use it will still fail.
What I do now is to just change the belt every six months as its a 30 min job, I can tell when it's gonna need to be changed soon as I notice small pieces of rubber around the engine bay.
What I did also though is to get rid of the plastic thermostat connector for the overflow pipe to a brass one tapped into the thermostat housing as this is prone to breaking when the belt fails, I use febi pulleys also.
Best,
Best,
