Front Lower Control Arm ADJUSTABLE
what do you guys think. I have to change my c63 c204’s LCA because of the bushing and the outrageous prices of the original part led me to run into this product. Wondering what you guys think.
Photo from eBay vendor next to original LCA
I’ve replaced all of the OEM bushings in all arms with heavy duty custom spherical bearings from SDW for increased durability and range of motion at the expense of comfort.
Combined with camber plates it’s the perfect combo in my opinion.
Bushes in question - front lower arm adjustable. They have the advantage of allowing fast, easy to access and precise single wrench adjustment plus retaining the high strength forged alloy factory arms.
Background was that bushes were 3 piece - center spigot “bonded to the inner bush”. Failure could occur (no matter what the tightness) if bushes were overloaded when dragging tires sideways at time of alignment.
Therefore saw the need to re invent - to make it bullet proof.
“Center is now one integral unit” - nothing to separate having completely eliminated the internal bonding (and followed up with a unique fail safe lock system).
W204 INCL. AMG & BLACK SERIES Instruction sheet (see spoiler below).
The Subframe (these models) is aluminum. Instructions show another design breakthrough where have designed so entire mounts are fully secured steel on steel - hardened steel bushes to specially designed steel mounts.
NOTE: Front “Camber” only adjuster kit #502616-1i $345 (Both Sides)
Less cost then 1 hi-performance tire.
Also includes bush extraction tool allowing fitment without need for arm removal.
Front Camber (also Caster) #502616K $480 (Both Sides)
Caster bushes also feature Mono ball / 2 Axis / Self aligning with more than “twice the load bearing impact area” of steel spherical bearings with their wafer thin Teflon liners soon pound out.
Rear Camber (& extra Toe) kit #502126K $480 (Both Sides)
Fit without need for arm removal.
Upper replacement Front top strut mounts Camber & Caster adjustable also manufactured in STAGE 2 Street/Race or Stage 3 Full Race. See website re all the unique features.
Kevin (Anything & Everything can be improved)!
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
Then having proudly “IN-HOUSE” manufacture - not sourcing imports. End result is Total Control over quality and with it allowing rapid/constant design improvements !
Kevin
thank you all for your input.
Then updating / replacing the soft rubber air voided OEM bushes with identical “large diameter” bushes.
SEE SPOILER RE K-MAC EXTRA FEATURES
Kevin
I never understood why people would put such hardware on their daily drivers.
If you want to enjoy driving it on the street (or especially a daily driver), I’d stick with rubber or polyurethane depending on bushing location or application. Just my 2 cents.
with the straight aftermarket arm contacting the rear subframe upon compression every time, this greatly accelerated wear and elongation of the spherical bearings used of which i've never had a spherical bearing need replacement through many years of abuse. also, elongation and stretch of centering spacers. quality bearings last a very long time even through 100,000+ miles of street and race use.
i support any brand that is constantly developing and improving their product and they've gained a lifelong customer in me.
and to add, the delrin or steel bearing design of the KMAC bearings on my W211 still feels as smooth as stock but with a lot more response and without deflection which equals more control even through suspension squat on power.
…..and it’s all about ultimate ongoing proving in all out heavy V8 Competition racing / loads not experienced otherwise - Full speed main straight then hitting corner race curbs and fully launching. Then slamming down broadside lap after lap. Situations where Race Safety Scrutineers pointing out over 12 months every meeting cars being written off through failed suspension components !
Proudly (on evaluating) saw was never happening with K-MAC. Then officially informing all drivers only K-MAC adjuster kits allowed to be fitted !
Kevin
