PS Pump Whine
Any suggestions before I replace the pump?
EDIT: I misread. I thought you replaced the pump as well. If it's whining then going away it could be the vanes in the pump not making a seal right away.
For peace of mind a good look over the hoses in the system for dampness/leaks, cleaning and re-inspection as required.
Make sure the fluid level is correct before you start it up.
I think at this stage you need to be confident it is not belt noise or related to another pulley the belt drives, if you are 100% in that order a new pump.
