C63 AMG (W204) 2008 - 2015
Unresolvable engine vibration... (W204 C63 M156)
Old May 7, 2023 | 09:04 PM
jason.amg's Avatar
C63 AMG
Hello.
I'm putting a lot of time and effort into resolving the engine vibration and jerk.
But I guess it wasn't easy.
My engine has a lot of irregular vibrations when cold, but at medium temperatures it is smooth,
and as the oil temperature goes over 100 degrees, the continuous vibration and jerk comes back.
So far I have carried out the following maintenance.
Engine, transmission mounts replacement (Mercedes genuine)
Engine head overhaul, valve wrapping, stem seal replacement and surface machining
Replacing timing chain and aligning timing.
Cam adjuster plates replacement
Tappets replacement (INA)
Intake manifold assembly replacement. (used)
Intake manifold overhaul, disassembly and cleaning, bolts / gasket replacement and adaptation (Mercedes genuine)
Replacing all spark plug coils (Delphi)
Replacing both oxygen sensors in front of the catalyst. (Bosch)
What should I do next?
Could the oxygen sensor behind the catalyst also affect engine vibration?
I knew that the oxygen sensor behind the catalyst was only used to monitor catalyst efficiency, but there seems to be other opinions.
I would like some advice.
Thanks!!
Old May 8, 2023 | 11:29 AM
skullbox15's Avatar
2014 C63
Injectors and flex plates?
Old May 8, 2023 | 11:41 PM
hooptierolling's Avatar
2009 c63
its a v8 its normal
Old May 9, 2023 | 09:56 AM
GarlicBread's Avatar
AMG C63
Do you have aftermarket exhaust?
If so, its possible its making contact somewhere and causing a "vibration" possibly on the cross bar where the pipes run to the resonator or where the resonator should be.
Old May 9, 2023 | 10:06 AM
chassis's Avatar
2017 GLE350 4MATIC
Read codes and report back.
