C63 AMG (W204) 2008 - 2015
Coolant Cap
Old Jun 28, 2023 | 04:17 AM
Ragunarok's Avatar
C63S Coupe
Coolant Cap
Hi I just noticed my coolant cap doesn't tighten on correctly - see attached. The cap itself is tight and I'm not leaking coolant but I thought the logo is supposed to be straight. Youtube videos all show it straight when tight.
I read somewhere pressure is vented from the cap so I'm a bit concerned that I have a faulty cap and it may cause a problem.
Advice is appreciated
Old Jun 28, 2023 | 05:32 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
if it's tight it's tight, the function of the vent won't matter. I mean if you want to buy a new cap it won't kill you and you could let us know
https://www.fcpeuro.com/products/mer...cap-2105010515
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Jun 28, 2023 | 09:11 PM
Ragunarok's Avatar
C63S Coupe
Thanks for your reply. I had a closer look at the cap.
There's two plastic prongs. The first, with the cap graphics straight, hits a nib but the cap is loose. When tightened, the second tab reaches that spot. I'm not sure if my cap or coolant resouvoir has a problem or if its normal. Below are pictures.
Cap is straight but loose in this position
Cap is tight in this position
Old Jun 28, 2023 | 09:49 PM
AMGSPY's Avatar
2014 C63 507 Coupe
Tight is the only criteria. The orientation of the cap is happenstance.
